jimbou1981
I just replaced my digitizer w/front frame, once I got it back together, the trackpad doesn't click. When I tested it out on my camera app, as long as I lightly touched it, it would take a picture, but if I press it with any force it will go haywire for a few moments like I'm repeatedly & rapidly pressing home/menu/back/search buttons. When I'm on the home screen I can slide my finger across the trackpad and it will move to the next screen like it's supposed to.
Do you think it's a problem with the trackpad or should I just re-open my phone and take every back off and try it again. The trackpad doesn't even "Click" when pressed.
. The phone still has had it moments where it'll act a bit crazy, but it's not as bad as it was. I'm thinking maybe it has do to with the little strip I had to remove from the old front housing and place on the new one.
