eriscentro
Member
Hello. My eris's trackball is now the same color as the body of the phone. I'd really like to clean the dirt off of it. What could I use to clean the trackball?
Funny, I thought when I left crackberry I'd never see another thread like this one!
We used to use just a LIGHT amount of alcohol. Also, rolling it on a clean sheet of paper will help.
Also, I think I used the trackball once in the beginning to see if it worked, haven't used it since--how does it get dirty?!
First, I would wash your hands more often.
How does the trackball turn black.....somebody has been touching things they should have not been touching
You might want to try some soap and water on your hands. Here is how:
Step 1: set water to warm, not hot
Step 2: apply a FAIR amount of soap to the outside of the hand
Step 3: move hands against each other in a soothing yet rough motion
Step 4: grab towel and dry your hands until they are as dry as the Saraha
Step 5: finally, your are able to pick up your phone and have fun
Step 6: bow to Porky101
