Help Tracking Data Usage
lazybones18
Is there a way to track what application is using how much data ??
It seems like there are some applications running in the background and sucking all my data. I want to know what are these applications or anything that is using my data .. Thanks
they only tell you how much data you have used
i want to know how much data is each of my application using on a daily basis
I have tried 2 of these programs. First the 3g watchdog and I am now using Onavo lite. Neither of them ever showed me using any data? I have no idea why it isn't working. Anyone have a program they are using that works good? Thanks!
PS - I know I am using data because I use my phone a lot off of wifi. I only have the 200 MB plan and I like to make sure I don't come close to going over.
I got it last night....i will post again if it doesn't work....i was just curious if anyone else had used the programs I did with any luck
I use "My Data Manager Free". It not only keeps track of how much data is being used per billing cycle, but how much each app is using too.
