Overview
This bulletin documents information (product differences) notifications and any known issues with short term work-arounds identified at launch. This info will be updated with fixes to known issues once the schedule is available.
Informative Notifications
Bluetooth Carkit Compatibility
The Bluetooth compatibility matrix
Accessories
The A855 has magnetic sensors to support operation with car holder and desktop cradle accessories. Holsters and cases that contain magnets are not to be used as they can cause false switches into car or desktop cradle modes. Refer the customer to case SKUs MOTA855CAS and PDASDPCH6.
Wired headsets have a higher volume than Bluetooth headsets.
Applications
Non-VZW Branded Applications
Google Maps can take several minutes to display the proper location and may be inaccurate when initially started. Accuracy can be improved by enabling GPS satellites by pressing the MENU button, select Settings, select Location & security settings and then select Use GPS satellites.
NOTE: Enabling this setting will have a negative impact to battery life.
11/8/09 - Google Search does not support voice input via Bluetooth headsets.
11/8/09 - Quick Office supports Microsoft Excel, Microsoft Power Point, Microsoft Word and Adobe PDF files. Quick Office is included in the device software and will not be removed when a Factory data reset is performed.
Wi-Fi access for Visual Voice Mail is currently not supported.
Activation/Over the Air Software Upgrades
Customers moving from a BREW device who subscribe to notifications (alerts) will need to have BREW block enabled to prevent notifications from being delivered to the device.
The Over the Air software updates will not display the maximum time required.
When using Factory data reset to initialize the device, it can take several minutes to complete. The reset will complete in the background.
POP3 Email
