Help Traffic widget in ICS?
lansing
I used the traffic widget all the time in my old phone with Gingerbread. Has anyone found the traffic widget in ICS? Is there something similar i can use with mu Samsung Galaxy Nexus??
Thanks
its there...wasnt on my phone after downloading google maps initially but after the ics upgrade to .2 i found it and currently have it on the homescreen.
Go to your app drawer, switch to "widgets" at the top and scroll over.
The widgets are in alphabetical order.
eyc: you can set a destination (ie; work, home, etc) and the widget will always calculate the amount of time it will take for you to get there.
on GB, the widget does eventually go to sleep but a quick single click on it wakes it up and gives you a time estimate.
It's extremely useful actually, especially on those mornings when you're debating whether to stay in bed an extra 5 minutes. ;)
  • Like
Reactions: eyc
