Help Transfer FROM SD to phone? Without pc....
ceider
Is it possible to transfer files, eg music, from the sd card to phone memory without using a pc?
The reason I ask is that my phone is constantly rebooting and I've heard that taking out the sd card helps. However I have all my music on there... :-(
Is it possible, or is there an app I need? I have es files app but can't see a way round it
All file managers will be slightly different but should be along the same lines. For the stock "my files"open the app and you should be on /sdcard. Create a folder called music and then scroll down to you external sd and find you folder with your music in. Press menu then move (gingerbread will be menu, more, move), then tick everything you want to move and press move. You should be put back to /sdcard. Now go to the music folder you created, and then click move here. It will take some time but eventually they will be moved over.
Thank you! I would never have worked that out, didn't take too long, and it's worked.
Now to see if it fixes the reboot issue.
Thanks again :)
