Transferring Contacts from BB9700 to DHD
Does the SIM method not work?
Save the contacts on the SIM from the BB and then insert SIM in the DHD and then import contacts, every phone has it, doesn't Android?
it seems THE ANDROID is someone who works in a store which just sells iphones and Nokia.. just trying to undermine android at every step.. its just pathetic..
neways DHD does allow you to import contacts from your sim.. that option is there in the menu of the contacts or people section as used in android...
@Danny.. the DHD supports something even better if you are using both the phones or if the contacts are on the phone memory of your BB.. the data transfer app...
Switch on your bluetooth first...
just go to the transfer Data app in the app list...
Select BB and then the model number.. if the model number is not in the list just select others and check if the DHD detects your phone... if it does you can trasfer contacts, messages and calendar entries from the BB to your DHD...
Njoy!!!!
