Transferring data from Eris to Incredible?
Amarah
This is probably the wrong thread/forum, so feel free to point me in the right direction.
I purchased an Eris 28 days ago with my NE2, and am upgrading to the Incredible tomorrow w/in the 30 day return window. I know how to transfer most of my stuff from one to the other (google sync, paid apps should be in the new market, save pics and docs to SD card, etc.), but is there a way to transfer my texts? I've been using Handcent, if that makes a difference...
tia
If you want to save the sms messages then I'd recommend using a simple app like SMS Backup & Restore. I've used it numerous times when wiping my phone. I love it.
You can also try SMS Backup. This one is synced to your gmail. I use it more than the one I stated above just because I don't have the need to restore my sms messages after wiping/switching phones.
Both are great apps.
SMS Backup v1.1.1 Application for Android | Tools
SMS Backup & Restore v2.6 Application for Android | Tools
*EDIT*
Also, using Handcent doesn't make any difference.
