Help Transferring data
ChampN252
My new SD card will probably come in today and I'm wondering how one transfers everything from one card to another? Txt messages and all
I use my computer (linux)
I make a back-up once a day (nanodroid and copy and paste the sd card (16 gb) contents to it's own dedicated partition on my hard drive
the only things stored on the SD card is cache data from apps and any pictures and music you load on their yourself.
if you have any apps installed to the SD card, move them to internal storage.
after doing that, connect it to your PC, transfer all the folders into the new card (after you format the new card) and pop the new card in your phone and your done!!!
text messages and anything else u do stay on the phone, except if your changing roms, then youll need to back them up with Go SMS
