Help Transferring to Dinc via USB crazy slow?
Afteraffekt
I had an LG Ally, and when I transferred to its sdcard via USB mounting, it would go anywhere from 2.5mb/s to 20mb/s, but with my Dinc, using the same card (reformatted) it goes 120kb/s! I have a feeling its due to the 2 storage mounts being present at once.
Are there any known fixes to this?
I never had a problem with the Ally, I have no clue why it takes so long, Ive asked friends with the DINC, and they state the same problem...hmm
Thanks for moving my topic, the sub forums weren't showing up on my phone! I see them now! ill be sure to use them in the future!!!
Have you tried different usb ports on the computer, or tried using something else to transfer files to your computer over usb and get the same results?
Only takes me about 2 mins to transfer about 4gb of data to my win7 laptop.
Uninstalling then reinstalling the drivers may help also. Try using the drivers from "htc sync" if you aren't already.
