Transition animation scale
Guys, since I updated to 4.3 I have noticed an issue with the transition animation scale..
I like mine set at 0.5 x but every now and then the option will reset back to the factory 1.0 x
The other adjustables will remain but this keeps reverting back!
Anyone else notice this problem?
Did you do a factory reset after installing the OTA update? Generally it's a good idea to do so as it fixes little bugs caused by files not overwriting properly (which can also lead to corrupted files). To me it sounds like what you're experiencing is a permissions issue. That would be fixed with a factory reset.
