Help Transparent menu for htc sense?
rjmendus
Hey guys, is there any way in which I can get a transparent menu for htc sense? Currently the background for the menu is black. I couldn't find anything in the settings area. If an app can do the job, then please tell me?
Thanks in advance!:)
Thanks for replying. I've checked out other launchers but I really want the htc widgets. Without changing to another launcher is there any other way?
My favorite app from htc is the htc friend stream. I like the widget too. And the weather widget is just cool, making the screen according to weather. @El Presidente: Do you use htc sense or any other launchers? :)
The Wildfire S is my work handset so I only really use the stock apps as I'm not really supposed to install apps on it.
My main handset, the Desire HD, I've used both Go Launcher and ADW Launcher Ex. Once you've not used the HTC stuff for a week or so, you don't really miss them. :)
