i think what Jong suggested may be your best bet
i would go to the Kitchen first and play around in the status bar area, it has status bar and notification pull down, you can customize and see if they have what your looking for
if they do have what you want you'll need to do an adb pull and get your framework-res.apk and systemUI.apk i believe (the kitchen will tell you whats needed)
then you upload your files to the kitchen, selected which mod you want, do whatever customizations you want, and finish and itll spit back out the files you uploaded, except they have your mod built in now
other then that im not sure, cause using a theme with a transparent status bar just doesnt work, well for me atleast, i have an ics theme that should have a transparent staus bar and notifications pull down, the pulldown is transparent, but the status bar stayed solid black, currently i just dont feel like goin to the kitchen to make it transparent tho lol
