JJ_Azevedo
is there any way to make your stock notifcation pull down transparent??
i think so? i dnt really know what that is im a noob to this stuff
In my experience the UOT doesn't work for making the notification menu transparent.
That's what I find weird about it. Instead of getting a transparent notification bar/menu, I get two of them on top of each other.wut
How?
You need framework and system ui, and GB + supports that
...and there's another problem, lol. Unless it's been fixed recently, stock++ wont flash UOT themes. I think it's framework.apk that wont flash.The rom has to be deodexed, it should work if your running stock++
