Cheers all! Great thread, just the info people will appreciate! With my Sprint non GSM Epic 4G, I know to keep it in airplane mode... but
a) do I need to turn off data, as well?
b) I assume it's airplane mode on, data mode off, then simply connect to any wifi from there and you should be safe?
c) If the phone turns off, does it reboot into no data, airplane mode.... or does it default to normal? And if so... what sort of charges will I see for the few seconds to lock it down?
Cheers all! Bon soir from Paris.
Safest bet is setting up a google voice account and forwarding it onto the GSM Flip device you can buy anywhere...
The Photon is world capable but I only use it for wifi while I'm out of North America, it's easier and cheaper just to create a G Voice account and give the important people your number...I just have both on my business card normally so it works out...
