I wanted to de-root my Nexus 4 so that I could safely apply the upgrade from 4.2 to 4.3. I had used Wugs toolkit to root the unit originally, so I tried to do the Flash Stock + unroot option. That didn't work. (I have a TitaniumBackup, as well as having copied all of my files out to my PC.)
The DOS window that opened up went through all the steps, then got hung up on reformatting the userdata area. After a couple of hours, I figured this was not going anywhere and stopped things. My current problem is this: Depending on which flash I've tried most recently, the phone boots through the Google screen and either comes up to the pulsing X, or the CyanogenMod Stargate. And that's as far as it goes. All attempts to restore using Wugs toolkit hang up on the userdata issue.
I've used ADB in Linux to hand-restore everything using various sets of instructions. Nothing works.
I've tried using CWM recovery, but I get errors when I clear data. When I try a wipe I get 'E:\ Can't mount SD Card.' I thought maybe the directory being missing was messing with it so I created /scdard to give the thing a mount point. It now skips the can't mount error and complains about being unable to access /sdcard/.android_secure.
I've tried using TWRP, that doesn't get me anywhere.
I've tried restoring stock recovery, but all that gets me is the 'dead android' screen when I try to go to recovery. In a moment of aggravation I tried flashing 4.3 directly, and that got me nowhere mighty fast. At the moment my current flash is to CyanogenMod 10.2.
I am open to suggestions. I've stuck my SIM in an old BlackBerry 7100 for the moment, so this is in the category of Minor Aggravation rather than Major Disaster. I have a phone, just not a very smart one.
