I have a request from a customer to write an app that requires privileges that are only available on rooted devices. To build it, I need a rooted device.
I followed some instructions I found to root the device, installing "UPDATE-SuperSU-v1.75.zip" and "openrecovery-twrp-2.6.3.1-deb.img".
I suspect this was a mistake. Now, the device never boots, and I can't seem to restore it. When I try to install the factory image from Google I get:
razorg-jls36i] ./flash-all.sh
sending 'bootloader' (3911 KB)...
OKAY [ 0.129s]
writing 'bootloader'...
OKAY [ 1.366s]
finished. total time: 1.495s
rebooting into bootloader...
OKAY [ 0.006s]
finished. total time: 0.006s
sending 'radio' (43814 KB)...
OKAY [ 1.378s]
writing 'radio'...
OKAY [ 2.304s]
finished. total time: 3.682s
OKAY [ 0.006s]
archive does not contain 'boot.sig'
archive does not contain 'recovery.sig'
archive does not contain 'system.sig'
Bootloader Version...: FLO-03.15
Baseband Version.....: none
Serial Number........: 05848a0c
checking product...
FAILED
Device product is 'flo'.
Update requires 'deb'.
finished. total time: 0.017s
I should mention I am on a Mac, and I have the dev tools installed.
Any help is greatly appreciated.
OKAY [ 0.129s]
OKAY [ 1.366s]
OKAY [ 0.006s]
OKAY [ 1.378s]
writing 'radio'...
OKAY [ 2.304s]
OKAY [ 0.006s]
checking product...
FAILED
