Root Tried unrooting now blank screen. Help!!!
melski415
I tried unrooting using some ruu downloads. It said it coud not finish something about the ruu. Now my hero just has a blank screen. What can I do?
What exactly are you trying to do? Unrooting seems a bit odd. Do you mean you are trying to go back to a stock ROM? If so which one are you using?
Unless your returning your phone, a stock ROm seems pointless, use Modaco 3.2, its better than stock
