Root Trien Juopeanutbear method... Partially bricked help?
JB3783
Ok let me start off by saying any grammatical errors I have will be resolved in the morning, I have quite a bit of alcohol in my system right now. Ok so I am using a Mac OS X Machine and used a virtual machine to try and install juopnutbear, it didn't work too well... then I had a problem and had to flash the recovery using fastbot on OS X. Not it keeps rebooting into juopnut bear no matter what I do. I have tried restoring my NANdroid backup, and have tried to install a fresh rom. I have absolutely no clue what to do :(
Any help will be appreciated.
Go hop on irc on the juopeanutbear website, the devs will help you get it running again.
FYI doing something like this through a virtual machine was a very bad idea, after you get up and running again, try again from a Windows machine.
