Trimmed ringtones storage?
g4rvd4
Hi,
I have trimmed a few mp3s to be used as ringtones.. But I've unintentionally made a lot more copies than I need, and now they all show up in the ringtones select list.
Where are they stored? Can I remove them manually?
Thanks.
Try Ring Remover
chart
Or if you don't have the Barcode Scanner installed :
Ring Remover for Android
Hi there, thanks a lot...
I had figured this out by myself, sorry I didn't post the solution here..
There's a hidden folder in the root of the sdcard called .ringtonetrimmer. You just need to navigate there with a file explorer like ES File Explorer and delete the files in it.
After that run sdrescan to scan the card again.
