trio stealth 4.3 ics
tlssmith
Hello not sure if I am in the right place sorry. I just got a Trio Stealth 4.3 Android is 4.0. Was great for 2 wks then it froze on android man dead with red exclamation mark in his belly. Did factory reset but wonder if I should've also wiped the cache partition as I did. Then reboot-same thing. One site called this a boot loop. I've read this tablet may be rooted by default. I would like to download to an Sd card maybe boot files or a recovery or even the stock firmware. I'm not sure of my options so if anyone can advise it would be greatly appreciated. Thx you
Hello there tlssmith!
I moved your thread into this forum so others can help.
Although I am not familiar with your device, you said you just got it.
I suppose if we cannot find an option here for you, is it possible to get an exchange?
And by the way, doing a factory reset should have cured your woes, and doing the factory reset should have cleared any cache partitions ;)
However, there may be something else amiss if you still are not up and running....
Let me see if I can find out anything for ya :)
thxs for such quick response. I have a Trio 4.3 internet tablet. Installed with android 4.0 ice cream sandwich. Is there a software I can install on an SD card to either boot past logo or what ever I need to repair/reinstall? Thanks. Theresa
yea that is the correct device thank you for your help. I'll try that one. I did factory reset but first time said wipe cache, I did. Now it says format cache partition. I'm scared to mess it up more. Also says F: failed invalid argument.
hi mike? Yeah got it for xmas but no receipt. I'm wondering if maybe you know if its rooted by default is there a Rom to recovery or reair? I've read that model comes rooted by default. I don't know rooting. It's not windows & I'm a comp tech. Thanks for your help. I'm not getting to much like it says, uhh newbie. Could be also hardware issue right?:. It's starting to make me crazy, 22/7 for real.
Hmmm, from what I've seen, those tablets are sold at WalMart?
Doesn't WalMart take returns without a receipt? Not sure on electronics though.
There isn't very much info out there for that device...but I do have a question....
The reset button---it is the kind you have to put a paperclip into a small hole to reset?
Hello my son works at tiger direct & got it awhile ago. Thanks for all ur help still can't find what to do, but I won't give up yet. I get viruses just to have something to do. None have got me stumped but this thing has! Do u mind if I keep u informed sometimes? Thxs again
Hello Mike this is Theresa I posted last month about a Trio Stealth 4.3 internet tablet that has a boot loop issue. You were very helpful at the time. I picked it up a few days ago to try once again & have learned alot. Pretty sure problem is sys files are corrupt. Been to like 1,000 sites, 99% sure i need to re flash firmware A10, but i just can't find a legit download site. I know about xda but they still don't offer a download for the firmware. Would u possibly know a site that really has the firmware download. Also i need to put it on an sd card as i can't enable the device to show up on my pc. I put an sd card in my phone and copied some files to it that said would boot it up and install them but uhhh nooo. So I thought about u again. Any help as always will be sooo appreciated. Thxs Mike I'll be waiting to hear from u again.....
