Root Triumph Volume
emmaa
Does anybody else have the volume problem on the Triumph after going to a different ROM? The stock VM ROM had a volume problem where it was really low and you had to do a trick to get it to normal working volume. The trick was to have music on and call voicemail, then you'd end the voicemail call and restart the music in which you'd then have normal volume. If you left the phone on silent, it would keep the loud volume, but if you weren't on silent and you received a text it would go back to the old really low volume setting.
Does anyone else still have this problem like I do with CM7?
