After a lot of thought, I finally decided I would root my Moment.... even the whole bricking issue had me really worried. I decided to try it anyway.
I got it all done last night... well, I think I did. I never actually went into anything that verified that I had rooted it.... just assumed it was rooted after the instructions I was reading said it was.
Well.... within these instructions was a link to the SDX website where I could download a custom update zip, and had a link to create my own update zip, so I chose to create my own. I'm not sure if I made some wrong choices while creating the zip or what, but now I am having some major trouble.
After creating my zip, I placed it on my SD card. Then, I shut the phone down, and started it up in recovery mode (maybe that's what it's called.... volume down, talk, and end buttons). I went to apply from SD, or something like that, and then went to the custom zip I had just downloaded. The phone did it's thing, said it was installed and then said I need to reboot. I did.
I've not been able to get into my phone since. It gets to the Samsung splash screen, finishes it's animation, and then nothing. It's just black. It won't do anything at all until I take the battery out and put it back in. Then, I am able to get to any of the startup screens.... or whatever they're called, but no matter what, always goes black after Samsung Splash. It could be that the phone is actually starting, but just not showing me a screen....not sure about that.
Well, I read a little bit, and decided I would try to fix it by installing a different update zip, so I put my sd card into my laptop and removed the custom zip. Then, I put the SD card back into my phone and ran the joeykrim zip again. It's still doing the same thing.
Has anyone got any ideas for me here??
I am so sick that I decided to do this. I sure hope it's worth it in the end. Thanks in advance for any help you can give!
