I'm having some problem booting in the bootloader, everytime I get into the bootloader it takes me straight hboot. I'm trying to flash a new rom as well as trying to get 4EXT to work. So what could I do to fix this?
Additional info, it says it is locked, s-off , hboot 1.57 .
you need to unlock your bootloader ---> HTCdev - Unlock Bootloader
Hes already s-off its unlocked fully it just says locked
surely you know better... they are separate why would you take the time to s-off and root etc without unlocking the bootloader?
When I ran Juopunutbear S-OFF it looks like it relocked but it seems that 4EXT will allow me to flash roms. Also if you read the instructions in the post http://androidforums.com/evo-v-4g-a...ing-evo-v-4g-roms-kernels-using-fastboot.html it tells you to be in the bootloader, these were the instructions I was trying to use but 4ext looks like it will allow me to do the samething.
You can't get s- off unless you first unlock your bootloader through htcdev.surely you know better... they are separate why would you take the time to s-off and root etc without unlocking the bootloader?
After you get s- off your bootloader will say that it's locked, this doesn't matter. Once you have s- off you can flash anything. If it really bothers you just push the unlock token to the phone, no need to go back to htcdev again.
you may be about 36 years older but you still kick ass with technology
I know allot of this but the problem is that when I cmdl into the bootloader it automatically goes to a screen asking do I want to update and then does not let me do anything else. I have removed any files used for rooting and all that so it must be something else. What my thinking is is that the sd card may need to be reformatted or repartitioned, may just pull an everything off of it, get an image of the card and then reformat.
with the sensation - twas a bit different. regardless what could it hurt?
Actually the Sensation is pretty much identical, the location for performing the wire trick is different but that's about it.
quick question : what is the wire trick lol I didnt have to do anything like that with any of the devices ive messed with. simply for curiosities sake (not intended to distract.)
My post was in response to kagevazquez haha who insinuated that unlocking the bootloader was a silly idea.
If you have s-off then unlocking the bootloader is unnecessary, it gets relocked during the wire trick. Having s-off will allow you to install anything, even with the bootloader saying that it's locked.
from my understanding s-off and unlocked bootloader are separate. s-off allows radio access to write and an unlocked bootloader does just that "unlocks bootloader"
