Help Trouble in downloading from android and connecting via browser
ravibabu
Dear All,
I am from Hyd
I have purchased Xperia ray 2 days back
Took uninor sim activated sim and data pack
Getting connected to youtube and android and some other apps
unable to connect to internet from browser
showing page cannot be displayed
when trying to download any app from android market
showing a message as it will be downloaded shortly
then in notifications panel i shows as downloading
but nothing happens even after hour
min size tried to download is 150Kb
I have updated os to 2.3.4 using Sony Ericsson PC Companion 2.0
Plz help me
Are there any settings if so Let me know
It sounds like you may be using WAP settings for data use instead of the required Internet settings. Please check this with your current network provider as this would be the most common cause of these problems.
Thanks for the reply
I have done factory data reset
and once again set the internet connections
I am able to download
The problem is solved
The problem was with the network provider settings
