Help Trouble Uploading Images to Picasa
davvy1856
Member
Anyone having any trouble uploading pics to Picasa? I have auto upload checked which works with pics I take with the camera but if I try to re-upload one or upload a screenshot, the phone doesn't display any Albums for me to choose from. The drop down does nothing and the Menu ellipsis(?) does nothing. So, hitting upload does nothing.
Thoughts?
seems google knows about it and are working on a fix.
there are workarounds posted from others users in the google thread on this:
Google Groups
seems if you have other sync accounts using the same login as picasa (crackbook, linked in, etc etc and do forth....) that is causing the issue.
removing all other accounts from your sync list and then attempting an upload may work--however some have posted once you add those other accounts back, the problem comes back.
not a big deal for me (im getting this error also--failed to retrieve account info), but i use photobucket...
