Help Trouble viewing flash videos
My phone is having trouble viewing flash videos. when a video is playing all i get is a green screen on the video and just hear sound. I can play flash games and see other flash content but not video. Any help figuring this out will be appreciated. Thanks.
Well flash should update by itself but just make sure adobe 10.3 is installed from the market. Also while your browser is open, go ahead and hit your menu button then settings. Make sure load images is always on, enable plug ins is set to on demand or always on. Before doing this just turn your phone off then back off to see and see if that'll help.
i have been watching flash videos since the Thrill first came out. The problem is (at least on my unit) is the latest Flash update 10.3.186.6. When i updated flash i had the same exact problem as you have. What i did is i unchecked the Auto update and i un-installed the update. now everything is back to normal. I'll just wait for the next flash build before i try updating again. I hope this helps you.
This did help. Thanks for the tip
Flash 11 is coming out but I'm not sure if that's for Ice Cream or not.
I think its for all devices running flash.. Im hoping it fixes the problem so i can update to that version
