Help Trouble with Kies Air
Just purchased SGSII recently. I'm new to Android OS infact this is my 1st handset that operates on Android. Need help on Kries Air. Not able to connect handset to my PC.
I have the following question
DO i need to download Kries Air on my PC first before trying to connect?
Welcome to Android Forums!
Yes, you must install Kies Air on the PC prior to attempting to sync your phone over WiFi. It should be on the CD that came with the phone, or you can download it from Samsung's web site.
Hey, I installed Kies Air on my PC, runs on windows XP. Started Kies Air on PC,then I connected SGSII via USB to the PC. I cud see on the top left corner (PC), "connecting device" rotating icon and then nothing happens. On the device I see "connected" message.
Need Help here!
installing Kies Air on the computer? im not sure if u guys mean installing Kies on ur PC.. but i didnt have to install any software to get Kies Air working. just run it on my phone, and open the web browser n enter the address given on my phone..i dont think u need to install anything?
You don't need to install kies air on the computer. It is very different to kies.
Just launch kies air from phone when on wifi. Then go to the URL provided by the phone on a PC on same wifi. Its browser based.
I connected device and PC to the same network via Wi-Fi, typed in the URL onto my web browser. The PC doesn't seem to connect. It take an aweful long time and everytime I had to close the browser since it does not seems to open.
Then I tried to install kies on my PC. Started kies on PC and connected device using USB. Kies shows a icon of left top corner says "connecting" and then nothing happens.
Need help!
Using Kies Air is very easy. Do the following steps
1. Connect your mobile to wifi network
2. Open the kies Air application in your galaxy s II
3. Click start button
4. it will show you a IP address with 8080 port
5. Type the address shown in your mobile in any of the computer (browser) connected in the same network
6. Your mobile will show a popup window to confirm the use of kies air through the computer click ok
7. Now the interface will appear in you browser
Use it:)
the first couple of times i did it it gave me trouble, made sure all peerblockers and firewalls weren't the problem, then it went nuts asking for permission (even though i tick remember) over and over again about 15/20 times.
now, it connects straight up.
remember to turn skies on the phone first THEN the browser. i have it bookmarked now and connects great.
(p.s. using firefox....maybe other browsers are blocking it somehow?)
I loaded it up using Firefox 4.0 on my iMac with no problems. It took a while to connect intiially but no more than 5 minutes and worked find once connected.
firefox > IE
*except the new 4.0, blows chunks and is slow. i kept the old version and just dont update :P *
firefox > IE
Really? I've noticed the exact opposite! :eek: Performance has increased and I prefer the layout too. I'm disappointed with Firefox for Android though, although I understand it's only in beta.
maybe they have sorted out the bugs, it was awhile ago....
haven't tried the phone version, just used dolphin via so many recommendations.
What's dolphin like? I've had no problems with the stock browser but am always interested in trying others out to see what they can offer
Hi could someone please help. I am trying to pair my s2 with my pc. My pc will not pick up the address via kies air. Any ideas :confused:
only thing i can think of is, did u type the full address properly? and after u enter it in ur browser, u have to confirm the connection on ur phone..
ok ta. i put the full address in and on my s2 it says online but pc will come up address not found. im starting to get square eyes and loose the will to live. :rolleyes:
and how do i comfirm the connection with my phone? thought it would just load. although i cant even get through the browser. just comes up no address found :mad:
Your phone and computer must be on the same wifi. If you are using your phone as a hotspot then connect your computer to the phones wifi.
yeah my phone is running of my home band so they are the same. so do i change the phone net as if i change my pc one it wont work and i will go offline.... im being really thick i know :eek:
hmm not sure why it wont work then. you could try it the hotspot way.
Disconnect your computer from your home broadband. Start the Kies app on your phone and click portable wifi hotspot. Then tick the portable wifi hotspot box, click ok then go back to the kies app. Connect your pc to your phones wifi (It should show up when you do a connection search on your pc). Once its connected, enter the address thats shown in your kies app.
its good, very fast, although that's just the phone really :D
i too am a bit torn between just using the stock browser...one downside is you lose the motion gesture with zooming in/out with another browser. if you like using that, stay with the stock....but really ive yet to give them both a good run, dam you angry birds!!
If your browser is not showing any result after typing the address provided by your phone, just go to Network (in Windows Vista, 7) or My Network Places (Windows XP) after starting Kies application on your phone. In Network windows, you should see something like (samsung GT-I9100 Kies air). Once you double click on it, a popup windows will show on your phone screen to confirm the connection between your PC and the phone, click OK. After that your default browser will open kies air with the same address given on your phone (http://192.168.xxx.xxx:8080).
Otherwise, try typing that address on a different browser than your default. If this doesn't work, try to check your router port settings.
i recently purchased a s2 and was comfortably using kies air. however, recently kies air (along with some other apps) is crashing when i click on the start button. any help would be much appreciated.
If this doesn't work said:
I have the same problem. Kies Air worked fine the first time I used it, but since that first time no browser can view it. I can see it in my network devices, the URL there agrees with the URL that Kies Air is telling me to use, but I can't see anything in the browser. I've tried Chrome (where it was originally working), IE, and Firefox.
What port settings are you referring to above ? Or is there possibly something else such as a firewall that needs setting ?
