Root Trouble with partitioning SD card using xrecovery
I'd recommend doing it with Windows.
There's a guide here: Properly Partition SD Card For App2SD+ Android ROMs
I second that advice. You can't do it with windows alone, since you'll want to have an ext (Linux) partition, which Windows can't create. This partition manager is free and I used it to partition my cards:
Best Free Partition Manager Freeware for Windows 7, Windows Vista, and Windows XP 32 bit & 64 bit. MiniTool Free Partition Manager Software Home Edition.
