Trouble zooming in and out with 2.1
Blizzard
In 2.1 when I open a web site it comes up very, very small - too small to read. Then, when I spread my fingers I can't make it zoom in and maybe 20 secs. later it finally works, but still not well.. The zoom worked much better in 1.5.
What am I missing?
While in the browser, go to menu, hit more and scroll down to settings, scroll down again and uncheck "open pages in overview".
Then they should open normally again.
What am I missing?
How long have you had 2.1 on your phone?
Did you do the factory reset after the update?
I had this same problem after the v3 leak update. After 3 days I decided to do a power off and that solved the problem, it works flawlessly now :)
And yes, Neera is correct about fixing the small pages issue.
