Root Troubles rooting 2.1 help please
pabeshky
Hi, had previously rooted 2.1 and tried to install app2sd, install failed and i lost root priveleges. Tried to re- root but keep getting errors
Starting ADB Server...
* daemon not running. starting it now on port 5037 *
* daemon started successfully *
OK
Waiting for device...
OK
Pushing rageagainstthecage...
2156 KB/s (585731 bytes in 0.265s)
OK
chmod rageagainstthecage...
- exec '/system/bin/sh' failed: Exec format error (8) -
OK
Running rageagainstthecage...
FAILED
any fixes
OK
OK
OK
OK
FAILED
any fixes
what exactly do you mean by app2sd failed? if app2sd fails the phone will be stuck at sony logo and I've never heard of losing root priviliges only unless you format your phone
Thanks, worked a charm
as expected
you see when you have eaten something you get calories and you have the energy to do work
but if you ate 10days back and since than your stomach is empty you cannot expect yourself to be active and fit
Killing ADB Server...
OK
OK
OK
cannot stat 'rageagainstthecage': No such file or directory
OK
OK
now it got stucked here....
wt to do???
