Help Trying to connect to LTE but Can't
SurrealOne
Android Expert
Not sure if this has been posted or not but I wanted to share with other forum members.
You will need your MSL number to complete the steps listed below.
If you absolutely cannot connect to LTE or stay connected to LTE, you can force your device into LTE only mode. If you do this, you will lose access to 3G EVDO and 1x services while in this mode. But it is reversible at any time. It requires your device's MSL code, though. You can get your MSL code by using some apps like MSL Reader, or by using a Terminal Emulator with some models. You can search the web for ways to get your MSL code of your particular device. Some people can even get it from Sprint CSR's.
Once you have your MSL code, go into your phone dialer and enter ##DATA# (*#*#DATA#*#* on the Galaxy Nexus). A menu will open and ask you to select Edit or View. Select Edit. Enter your MSL number. Now in each device, there may be some variability in the next steps. Select the Others button, then choose HDR/1X selection. Select LTE Only mode. Now you will only be able to connect to LTE, no 3G or 1x. However, you will not be able to make/receive phone calls or text in this mode. Data only.
Once in LTE Only mode, you will only be able to connect to LTE signals. Even weak LTE signals. And you will not have to worry about getting shoved off into 3G. This will allow you to test your LTE, and make sure your LTE is indeed working in your device. You could stay parked in this mode if you wanted to. You just wouldn't be able to use the phone or text. To restore to normal, just go back in the same way and select LTE/CDMA or LTE/CDMA/EVDO, depending on your device.
If going into LTE only mode you are still unable to connect to LTE, then you are either not in LTE coverage like you thought you were, or your device has a problem.
This can also be found on like listed below.
Sprint LTE launch market connection issues - Sprint 4G Rollout Updates
The steps are a little diff for the S3 you do ##data# or ##3282# select edit enter your MSL code select HDR/1x and then you can select LTE only mode.
You can get your MSL code from Sprint CSR.
This is a hidden programming menu.
Could you elaborate? It wouldn't install? It didn't show the options indicated above? It did show them, and you tried them and nothing happened? What?
I can..
Install was fine no problem.
Went to device info and changed setting for LTE only.
Then I went into the Programming menu ##data# and my device was still on LTE+CDMA+EVDO Mode Please see attached photo
Best to not use APP's to change phones hidden Menu's IMO. My first question would be what ver of device was the APP for? Sprint? Verizon? AT&T? And IMHO I would rather not install an APP that can change my phone settings with out some sort of code like the MSL.
