I managed to S-OFF my phone but I got stuck with the recovery. I'm not bothered what product I use, just want to sort it out before I reflash.
I'm completely new to this world and spent half the night reading up before I started.
Been following this guide:
http://androidforums.com/desire-all...ry-windows-published-4th-november-2011-a.html
Here's the bit I got stuck at:
ADDING CUSTOM RECOVERY
6) it's time to install your recovery file.
a) Boot into fastboot mode (from off, volume-up and power or volume-down and power then cycle to fastboot option)
b) Connect phone to PC through USB. You should see "FASTBOOT USB" on your phones screen.
c) Open CMD (Start > Run > type "cmd" and press enter)
d) Type "fastboot flash recovery c:\your recovery file name" where c:\your recovery file name is the exact location and name of the recovery file you downloaded.
When I run it, I get the following error:
C:\>"fastboot flash recovery c:\recovery_CWM_2.5.0.7"
The filename, directory name, or volume label syntax is incorrect
I've tried various combinations of .img .IMG on the end but no luck and as I say I'm not really sure what I'm doing.
Anyone got any thoughts?
Cheers,
Drackie
Cheers,
Drackie
