Trying to install the Droid X Driver, but I get an error message, "this installation package is not supported by this processor type." Can anyone help out?
Rooting Your GingerBread System .602 (Will Root .605 as well)
-Make sure you have Motorola drivers installed - [Download Drivers]
-Download and unzip ‘Psouza4's 1 Click Root′
-On your phone: Settings > Applications > Development > USB debugging(check box)
-Plug phone into computer
-Navigate to the folder you unzipped 1 click root to and run ‘MotorolaOneClickRoot’
-Now just follow the instructions in the command window and unlock the phone after each reboot.
