Root Trying to upgrade my Android to 2.3.5 but not working
Sir Black
I have an HTC Chacha, Android 2.3.3, after rooting I received a msg that system software update to Android 2.3.5 is available. I downloaded it and it offers to install it, when I click ok, it takes me to CWM recovery but then gives me this error:
E: can't mount SDCARD:download/OTA_Chacha_S_Cingular_US_2.14.502_R-1.23.502.1_release_248619vexii1vm988w1oh8.zip
Installation aborted.
if I try the Install Zip from sdcard option, it gives me :
Finding update package...
Opening update package...
Veryfying update package...
I then get this error message:
E:failed to verify whole-file signature
E:signature verification failed
Note that when I installed Link2app and after repartitioning my 8Gb SD card (1Gb partition as second partition) and enabled swap, it asked me to specify the partition I want to use, the only option that worked was ext3, as ext2 ex4 and Fat didn't work so I went with the option that worked. (I hope I remember this right it might be the ext2 that worked, I am not sure, but I remember it was ext3)
Any idea who can I make this update work?
Thank you in advance.
