Root Trying to upgrade
SurrealOne
Android Expert
So I updated my phone to DK28 then rooted it useing one click then I put my phone back to stock eclair all is well now...But I want to upgrade back to DK28 with EXT-4 when I try to upgrade DK28 it's not working I got the DK28 zip file and renamed it copied it to root of SD and now when I run the file I get an error (status 7) is the message. Any Ideas what I can do to get this going?
Found the problem the file that I downloaded and tried to use for odin the file was named SPH-D700-DK28-8Gb.tar.md5 I renamed it to a .tar and upgrading now. Good to go :)
Yes got it all going now and looking to install the new
[ROM] midNIGHT ROM v2.9 EXT4/RFS CW2.5 Redirect (CW3 Compatible) 1/13/2011
