Help TurboDies suddenly
Lollipop 5.1 or kitkat4.4.4?
  • 5.1
    Votes: 1 50.0%
  • 4.4.4
    Votes: 1 50.0%
  • Total voters
    2
  • Poll closed .
ford0921
My 64gb ballistic nylon Motorola droid turbo is experiencing some odd hardware of software failure. I will be any said task and it will just immediately cuts off no shirt down to me it seems like a battery issue. You guys think it could be the battery, hard drive? Or 5.1?
BTW I can't think of anything off the top of my head that I like more about lollipop, KitKat was an awesome system I would take it back if I could.
Welcome to Android Forums.
Did you do a Wipe Cache Partition after upgrading to 5.1 (removing all temporary data and not touching permanent data or settings)? It will run about 10 min and is highly recommended.
Did you try running in Safe Mode (disabling all apps you added without uninstalling them)? If the problem stops it is caused by an app that you added.
... Thom
