Turn off sound when USB connected?
Esabasard
Member
Is it possible to disable the notification sound that plays when I connect my phone to my PC? I tried unchecking SD card notifications, but thats not it. It is really annoying to have to hear that loud sound when I am in the office. Thanks
Is that the only option available. I know that I can kill sound, but I was hoping there was a way to disable it. Maybe it just isn't possible.
If you don't have USB debugging on and you turn off the notification sound, it will be quiet. I found last night that if you have USB debugging on, you will get the sound. It seems to me that the debugging mode overrides the notification setting.
On Droid X I cant find the option to disable the notification ringtone. there is no "None" option.
2.1 here.
If it helps, on my Acer Liquid, instead of "None", I get "Silent", which I think has the same function as a blank sound file. Haven't tried this yet, but I will!
