Help Turn Off Typing Sounds?
techgui
Other than turning down the volume, is there a way to turn off the typing sounds? Also, is there a better app for typing and editing? I'm using the stock app that came with the March release of ICS.
Thanks
Thanks
If you go under settings / language and keyboards / input , or some combination of that. I'm not 100% sure, it can be different depending on your device.
In there you should see an option to turn off keypress sounds. :)
Thanks
Try Hacker's Keyboard on the Play Store.
