A Android Question Guest Nov 19, 2013 #1 How do I turn 3G on, on a Kyocera Hydro? Tried to go to settings, more, mobile networks. Didn't work
Brian706 I like turtles! Moderator Nov 19, 2013 #2 If you have the setting turned on (which it sounds like you do) is it possible that you just aren't getting 3g coverage in your area? If there is good 3g coverage in your area and you aren't getting it, I would visit your carrier and ask them why you aren't getting 3g.
