mistichunter
hey guys all u out there who have the anyoing regular android keyboard. a few days ago i found an easy way to bypass. swype unto the motorola triumph. here are the steps on how to get it installed.
!!!!1THIS FOR THE FOLLOWING VERSION OF CYANOGENMOD ONLY!!!!!!
>>>>>>>update-cm-9.0.0. triumph-Alpha-0.5.1-signed<<<<<<<<<
1. go to Swype | Text Input for Screens
2.click on get swype beta
3. clikc download swype beta
4. after that fill out the registration form. in my case i used my gmail account so i can receive the link directly to my phone.
5.go to system settings on update-cm-9.0.0. triumph-Alpha-0.5.1-signed
6.CLICK ON Security
7. Select and chech Unknown Sources
8 Open Gmail or ur email app . by these time uve have already assumed registered on the site link above .
9. open the confirmation link on the confirmation link. its has a 5 digit code.
use that code after opening the link
10. after u open ur link it shouls automatically take to a download page. and should start downloading within a few seconds. i recommend u use wifi for faster and time saving.
11. after that clik on the downloaded link .
12. Click install ---have unknown sources cheked so it can get installed.
13.CLIK on open
14.CLICK on login
15. use ur username and password clik login use the information u submitted on the registration page. for ur username and password.
16. CLICK on swype beta and select download skype
17 CLICK INSTALL
18 CLIK ENABLE SWYPE
19. SELECT SWYPE AND UNCHECK ANDROID KEYBOARD
20. SELECT SWYPE AND CLIK ON FINISH
and thats how u install swype on motorola triumph.
6.CLICK ON Security
13.CLIK on open
14.CLICK on login
17 CLICK INSTALL
