Help tvcatchup issue since 2.2
Status
Not open for further replies.
Hello all
tvcatchup worked pre 2.2, i've upgrade to 2.2 and now when i try one of the channels through the mobile version a popup appears saying The content is not supported and then it downloads a m3u8 file, but i can view them fine through the actual website..
anyone else having any issues or seen this before?
Thanks,
Me
I have just tried it on my 2.2 and its working fine, but my version isn't the official version. Are you pointing your browser to m.tvcatchup.com as it sounds like your on the iphone page.
Let me know if this helps.
I have had this on 2.1
I am fairly sure it worked from android.tvcatchup.com, until I installed snesoid,gameboid, gensoid and nesoid (all in one go). Then it did as you described.
Uninstalling snesoid etc did not help.
Had you installed snesoid etc?
Status
