killcmd Well-Known Member Jul 8, 2014 #1 Anyways I took some INIT.D scripts from my [nano] ROM and it sorta improves the responsiveness. DOWNLOAD
JerrysKids Well-Known Member Jul 8, 2014 #2 WHAT THE WHAT? Random! So what does this mean for us LG L70 folks?
AndyOpie150 <strong> <a href="http://androidforums.com/optimus Jul 8, 2014 #3 Thanks killcmd: Have downloaded. Will try today. Will look at entropy value before install and after. Will post results a little later.
AndyOpie150 <strong> <a href="http://androidforums.com/optimus Jul 8, 2014 #4 md5 sum matches, but it fails to extract. What did you use to compress the files? Try puting them in a folder within a folder. Then compress.
