Bichofelix
[Updated 9/6/15]
Works for both cm and stock.
I am not responsible if:
So.. What is it?
It's a simple script that automatically sets governor settings, read ahead to 2048, and scheduler to deadline. Also enables ZRAM of 512mb
The main reason I created it is it sets freq_min to 200mhz instead of 800mhz.
What are the benefits of this?
It scales better according to load.
Potentially better battery life.
Solves a major heat problem on the Leon, not seen on the GStylo
Idles at 200mhz half the time it runs 1.2ghz
How do I use it?
Enjoy
- Your house blows up or your kitten dies.
- If you had a super important meeting and your alarm just didn't go off.
- Your phone mysteriously catches fire.
- You didn't follow directions.
- You spontaneously combust.
So.. What is it?
How do I use it?
- Download HERE
- Use file explorer and go to /system
- Create a folder called "su.d"
- Give folder rwx-rx-rx permissions
- Place file in folder.
- Give file rwx-rx-rx permissions
- Profit!
Code:
Changelog:
[*] V1.4 - Added su.d support for both stock and cm. Added Zram of 512mb. Added support for GStylo. Merged stock and cm scripts back.
Enjoy
