radiowackoman
Member
I should've never started messing with the themes on my phone >_<
I just reapplied the StockTheme from VeloCyanRC, and immediately noticed that my Twitter widget never loads if I have to reboot my phone. It just sits with the loading circle, and I have to delete it off my home screen and reapply it.
At first, I thought it was because none of my accounts had been set up auto-sync, but now that they are, the widget continues to stall upon loading. I should note that I'm back to using the stock launcher after using GO Launcher EX. Any tips?
