Help Twitter Widget
kstruck
Can anyone recommend a good Twitter widget that allows scrolling? The ones I have tried Twidroyd and Plume, scrolling on the widget will not work with Sense.
I really don't like the HTC twitter widget. Would also prefer widget that fits the whole screen.
Thanks in advance.
No I tried that first. It is not scrollable and just show one tweet at time.
I had one on my Captivate that was full screen and scrolled I just can't remember what it was. It was probably a Samsung widget.
The Sense widget scrolls and is full screen so I will probably just go back to that.
If anyone has any other suggestions, please let me know.
sorry i think the twitter or friend stream is the only one that does that then
Yes, I am trying out FriendStream now.
Since the Facebook widget refuses to update or does like once every 12 hours, which is driving me nuts, Friendstream looks to be pretty good.
this is the one i use it syncs my twitter and facebook in one its scrollable and updates, depending on your settings
I guess I need to revisit that FriendStream option. I was under the impression that it was just reduce the battery, quickly...
The Sense widget is your best bet.
There's something very similar called Colorize Widget that includes a Twitter widget and you may like better or it may have options you prefer
Colorize Widget - Android app on AppBrain
screen
none of the sense widgets decrease battery the phone is designed and optimized to work with sense if your battery life is that short that your shutting all the functions and use of the phone then exchange it because there is no point in having an Inspire and not using it to its fullest
...bloody good point! I've always hated 'turning off' things to accommodate having more battery life.
I too am on Sense and looking for a good Tweeter WIdget. The Sense widget takes up the whole screen and I really am looking for one or two lines that then can scroll. Plume seemed to work a little but not anymore. ANy ideas would be appreciated.
