RJB
Member
I just bought the TMo Note on Sunday, so I'm still learning a lot.
Been using the original Galaxy S with 2.3 up until now.
I'm not interested in rooting.
Two features I liked on the S that seem annoying on the ICS Note.
USB Mounting
On my S, I plugged in the USB, and it gave me three options -
On the Note, it's a lot weirder. To me.
I plug in, it automatically connects as a "Media Device (MTP)"; I can select "Camera (PTP)". But neither mounts as a drive (although in Win Explorer I can see flies). No, if I want to mount, I have to go to Settings->More->USB Utilities->Connect storage to PC. Then I have to plug it in. THEN I can select "Connect USB Storage".
Surely there's a widget out there that will make it more friendly - so I can just plug in and mount. Why would they make something MORE complex over time??
Data network Mode
On the Galaxy S, if you long-pressed the power button, it gave four options: Silent, Data network mode, Flight mode, and Restart.
"Data network mode" turned off the 3G antenna. If you were set for Wi-Fi, you still got wi-fi. Phone and SMS still worked fine.
On the Note, I have to Settings->More->scroll to Mobile networks->Use packet data.
Surely there's a widget out there that will make it more friendly - I can just push it and turn the 4G antenna on and off. Why would they make someting MORE complex over time?
I've Googled the Play store, and can't find anything that seems to work. So I'll take your suggestions.
Thanks!
USB Mounting
- Kies (Firmware Update)
- Media Player
- Mass Storage
Data network Mode
Thanks!
