crystalce
I just got a replacement S3 due to a cracked screen. In reinstalling my apps, I've encountered two annoying issues (so far...) and I've tried getting assistance from the apps' creators, but no luck. So here I am...
1) Handcent SMS: Since installing it on the new phone, I can't change my own contact picture. On my old phone (prior to the JB update) I just tapped the grey silhouette that represented my part of the conversation and it let me choose a picture. Now nothing happens and I can't figure out another way to do it. I contacted Handcent, but no response...
2) My Motospeak: It worked perfectly on my old S3 (again, installed prior to the JB upgrade). Now, I can't get it to set as the default. According to the app's instructions, when I press the call button I should get a pop up window that will ask if I want to set Motospeak as the default. Pressing the call button results in nothing happening. Well, it did open S Speak until I disabled it. I haven't changed my bluetooth device...it's just the new phone.
Any advice for either would be appreciated. The Handcent issue is just annoying. The Motospeak issue is more serious, since we have a hands-free cell phone law in my state.
Thanks!
Thanks!
