Root two issues
djb28
I am running MIUI and yesterday I started getting force closes. Mainly when I would select a contact to call or message. I found a thread somewhere and did what was instructed. Nothing worked so I ended up downloading the new Vicious V5 file and loaded it up. All works fine.
Until.. I synced my contacts. They loaded to the phone But when I click the phone icon by the name it says. "no number" I can open the info and see Html text in brackets.
Some names the info is in proper format and The numbers are there. But even still it says "no number" when I click the phone icon.
I can edit each number and put in their information . But that is a lot of names and numbers! I hope I explained it clear enough for someone to give me an idea as to what is up. Thanks.
FIXED:
I found that if I clicked the name in Gmail all the numbers were still there in the text field. I just copied and pasted them to reflect in the phone number field. Dont know why they deleted in the first place, or wouldnt load properly. It took about 20 minutes to do, and I am sure there is an easier way. I just couldnt find it.
