Root two sdcard folders???
beastinbolts
Android Expert
When I go to the root of.my phones file system. I have two sd card folders.. that's new to me.. I started poking around because I kept getting a notification saying "sd card blank".... ???...but that was of course not true.. I then went ahead and partitioned my sd card and that got rid of the notification... But I still have 2 sd card folders.... Is that normal with the rezound?
Also a2sd won't work for one of 3 reasons... No script found, no ext partion found, or not rooted... I am rooted so how can I tell which one of the first two is the problem
your removeable sd card is "sdcard2". the other is your internal storage.
i personally have not ever bothered to use apps to sd with a device containing decent internal storage and ram,nor have i ever changed the filesystem to ext 3 or 4,nor have i ever partitioned an sd card.
+1 to what Scotty85 says. You can also get to the removable storage at \sdcard\ext_sd.
I never have either... Never had the need... But I was reading some where that ICS uses ext4.. so I figured I needed to do the partition before flashing.... Guess that was wrong huh
